01-07-2024 11:51 AM
I signed up on Jan 4th using the app. Everything appears to be in order and yet no service. Can't make or receive calls, I have to use email to get verification codes - no text msg and it appears that I have not data. Fido has cancelled service so I am high and dry. Please advise.
01-07-2024 12:26 PM
HI @SRL2024
my experience is agent usually reply mine within 2 or 3 hours
But if it is eSIM, check your Sim manager or Settings-> Cellular and see if the PM sim card is installed already, maybe just not enabled. If you have iPhone, you need to set the PM esim as Primary and enable "Turn on this line"
if you don't have the esim there, check if you got PM Welcome email , there is a esim qr code there for you to install
01-07-2024 12:22 PM
esim. How long does it usually take to correct something like this?
01-07-2024 12:03 PM
@BKNS27 wrote:Did you reply to the text from Fido confirming you are porting over to PM within the 90 minute window?
This is the most critical step in completing the porting process but I hope you didn’t cancel your service with Fido before activating your SIM/eSIM because it needs to be activate before porting over.
You will need to contact a CS_Agent to help to complete your porting.
While there could be a porting issue, the part about not being able to make outgoing calls isn't. There's something else going on with the Public Mobile account.
01-07-2024 12:00 PM
01-07-2024 11:55 AM
@SRL2024 Submit ticket with support to re provision the SIM and re fresh your account
send a private message To CS_Agents
01-07-2024 11:54 AM
HI @SRL2024
physical or esim?
it is just a sim and account setup problem. Agent can refresh the account and make it work, please submit a ticket with CS Agent here:
