No Service
07-10-2023 05:12 PM
07-10-2023 05:14 PM
07-10-2023 05:14 PM
HI@Jack13
not able to connect at all? non data and no voice? you tried to connect in another area ?
07-10-2023 05:14 PM
Did you check if your account status is active? To avoid browser cache confusing, please login My account using Incognito mode to confirm account status
If it shows On Hold (Suspended) , then it is a payment issue. Click "Pay Now and Resume Services" to make a manual payment
If it shows active,
- first try to reboot the phone
- If that does not work, change the Preferred network type or network mode to 3G only or WCDMA only and see if it works
- Try to click Reset All Networks and see if it helps
- and do you have another phone to test the PM sim ? just to make sure it is not a device problem. Also, that can force a sim card re-provision and it could resolve the problem
- Also, try the phone in another area if possible, it could be just a local network outage
07-10-2023 05:13 PM - edited 07-10-2023 05:14 PM
@Jack13 @Dial *611 or log into my account is your account active or on hold ?
also check
Outage map in your area:
https://istheservicedowncanada.com/
