No Service after eSIM to eSIM transfer
NatG2
I recently switched to a new mobile plan and transferred my number from another carrier using eSIM to public mobile eSIM. The payment was successfully charged and my account has been created, but I still have no mobile network connection.
There is no service at all — I cannot make or receive calls, send text messages, or use mobile data.
I have restarted my phone, but the issue has not been resolved.
9 REPLIES 9
hi @NatG2
how would your number ported to your husband's?  PM system is one email for one account, if you have 2 accounts with PM, you need two different emails to create two accounts, maybe you have used the same email ?
ask PM support agent to clear up your situation, you can submit  ticket by direct message:
NatG2
Hello. I recently switched to Public Mobile using an eSIM and transferred my number from Virgin Mobile (eSIM).
Mobile data is working, but I cannot make or receive calls, and I cannot send or receive SMS.
My previous Virgin Mobile account was under my husband’s name, and my phone number was part of his account.
How can I check if the number porting was completed correctly and if voice and SMS services are fully active on my line?
LeePublic1
Did you activate via eSIM or physical SIM?
NatG2
iPhone
LeePublic1
What model is your phone? Is it a Android/Samsung/Pixel or iPhone?
hi @NatG2
you removed your old carrier sim card? And make sure PM sim is enabled and set as Primary.
Then reboot phone and reset network settings and try
if PM is a physical sim, try it on another phone
but if you need PM support agent to help,  you can submit  ticket by direct message:
NatG2
I got public mobile plan after yesterday for my phone, I opted to transfer the phone # from the old service provider. I got the SMS to initiate the transfer, but now I can’t make outgoing calls, I don't receive incoming calls on my phone
Frank52
Hello, you can review the following steps. It might help with the Esim issue:
https://www.publicmobile.ca/en/get-help/articles/transfer-your-number
Additionally, here is a ESIM FAQ document:
https://www.publicmobile.ca/en/get-help/articles/esim-faqs
Sansan
Check that you've disabled,  not deleted your previous eSIM and enable the PM one.
