04-27-2022 04:37 PM
Transfered my Iphone SE 1 hour ago. It says no SIM - but my iPhone is already unlocked. What do I do?
04-29-2022 11:50 AM
@ykacamak wrote:It does say no sim restrictions
@ykacamak - you must activate a new or unused Public Mobile SIM card with a plan in order to have services with Public Mobile.
Did you activate in-store or online here through the activation pages: https://publicmobile.ca/en/on/portal/activation
If you have activated a new account and transferred over from Bell (was this a landline or mobile):
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
If you missed the text to approve the port, is your Bell account still active? It must be active to successfully port over to Public Mobile.
To re-initiate the porting request submit a ticket with Public Mobile representatives (CSA), click this link: to request the transfer of your number over to Public Mobile.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
04-27-2022 05:15 PM
Did you just activate your pm sim card? If so contact customer support and put " SIM card not provisioned upon activation" in the subject line and leave a detailed message explaining the issue.
Keep an eye on the envelope icon next to your avatar at the top right corner of your screen for a little number to pop up indicating a reply from a CSA. Responding promptly will speed up service times but expect a reply within an hour.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #
04-27-2022 05:06 PM
04-27-2022 05:04 PM
Check in Settings / About / Carrier Lock and if it says No SIM restrictions then your phone is unlocked.
04-27-2022 05:01 PM
Are you sure your phone is unlocked? You can check by connecting to iTunes if I can find the procedure for you. Or call Bell MTS back and ask for them to put your request into Apple for you. Customer service reps often tell you your phone is unlocked when in fact it is not.
04-27-2022 04:52 PM
It uses a Bell MTS sim card and worked just fine until the switch. It is from Bell MTS and I checked the settings and it says "no carrier"
04-27-2022 04:49 PM
Then this is a device issue. Where did you get the phone?
04-27-2022 04:49 PM
@ykacamak while it could be a defective sim, it could also be just a SIM provisioning issue and can be fixed quickly. Open ticket with PM Support first and have them confirm if the setup on the backup is done properly. Worst case, if they think it is faulty sim, ask them for reimbursement and you go and get a new replacement SIM 🙂
04-27-2022 04:47 PM
I used the SIM with my work iPhone and got the same NO SIM.
04-27-2022 04:43 PM
Remove your sim card. Check for any dirt or debris in the SIM card slot or on the sim card. Reseat the SIM card and make sure it fits snugly in the SIM card tray. You may need to use a paper shim or a little piece of well placed tape to secure the SIM card in place. Reinsert the SIM card and reboot. Do you get the same message?
04-27-2022 04:40 PM
@ykacamak Do you have another phone around to test the SIM?
If not, still try to re-seat the SIM (power off the phone, take it out for a minute, put it back in and power on) to see if it works.
If it still not working, it could be just a SIM provisioning issue and PM can easily resolve it. Just open a ticket with them:
1. If you have access to My account: Click on the bubble on the lower right or https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
