No SIM Emergency call only
ZZOPPA
The subjected sign has been on my phone and my contact information on my SIM was disappeared.  How can I solve this problem.
HI @ZZOPPA   Did you try to put your sim card in another phone?
Also, do you ever use SIM pin?
Timer
@ZZOPPA
turn off device take out SIM card and reinsert back turn on.
and Check the Status of Your Device in that website
devicecheck.ca/check-status-device-canada
How check IMEI number  Dial *#06# on your phone.
use browser from computer,clear cache and cookies and use one page inPrivate mode,
To Login Page
your account status is Active.
will13am
Looks like a phone failure to me.  SIM cards are much more reliable than the phone.  It is easy to check which actually failed.
Yummy
That is not good. It looks like SIM failure. 😞
Try SIM in some other phone. If it fails look on Internet if there is some kind of SIM recovery app.
MrSpock
hi can you try your sim in another phone to see if it works?what type of phone do you have ?
