10-19-2018 01:36 PM - edited 01-05-2022 02:12 AM
I purchased the Public Mobile sim about three weeks ago, but there's been no network. My phone is compatible with the sim--I checked before purchasing the sim.
10-19-2018 01:40 PM - edited 10-19-2018 01:40 PM
@Mkumar What phone do you have and where did you check the compatibility?
Log into your self-serve account and see the status of your account.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
10-19-2018 01:38 PM - edited 10-19-2018 01:41 PM
@Mkumar wrote:I purchased the Public Mobile sim about three weeks ago, but there's been no network. My phone is compatible with the sim--I checked before purchasing the sim.
No network the entire time?
Does your account show active? Do you have a plan? What plan are you on?
Have you tried the sim in another phone?
Can you tell me the exact model of your phone? The IMEI checker at public mobile is not very good.
Has your phone been listed as lost or stolen?
Have you tried to do a manual network search?
What happens when you try to make a call?
Have you tried re-inserting your sim?
Have you tried turning air plane mode ON then OFF?
