11-08-2020 05:13 PM - edited 01-05-2022 04:03 PM
Hello - I am reaching out on this forum as a method of gaining support as there is no email or phone support to my knowledge.
I recently (October 26) switched plans but kept my phone and existing phone number. I had already purchased a SIM card and plan from Public Mobile and completed the registration to port the phone number to the PM on Oct 26th. Oddly enough everything went very well and as soon as I inserted the PM SIM card into my phone I was able to call, receive calls, message and use my data. I thought this was great and went on my way.
This last week my phone stopped ringing and when I try to call I receive the following message " The Client you are trying to reach is not available right now, please try again later". I don't know what happened as everything was initially working well for about the first week.
Is a moderator able to please assist?
Joining Public
11-08-2020 05:31 PM
@saskgui Have you tried basic troubleshooting on your phone? Try removing and reinserting the sim and try rebooting your phone. To eliminate the blame on your phone, try the sim in any other unlocked phone if possible and test the phone calls on it. If that works, it could be your phone. If calls do not go through, something might be wrong with the sim or your account.
11-08-2020 05:28 PM
Thanks for the reply. Yes I can call out and yes my account appears to be active in self service. At least it is counting the data I use correctly. I have contacted a moderator.
11-08-2020 05:15 PM - edited 11-08-2020 05:16 PM
![](/skins/images/02B49C0B2FC614613D221373CF8AAEF5/responsive_peak/images/icon_anonymous_message.png)
