No GOOGLE
07-13-2021 03:59 PM - edited 01-06-2022 02:47 AM
After 2 hours fooling around I finally got onto INCOGNITO and bought the $25 dollar 500GB plan,phone works but nothing else,no browser(Google),no text with a picture,this service is starting to look like a waste of time or is it me,please help me I need this up and running I am going to Florida in 48 hours.
Joining Public
07-13-2021 08:21 PM - edited 07-13-2021 08:21 PM
from Amazon on another SOYES phone
Q: How do you connect it to the internet. I have chatr canada and i can make calls and i have data but it wont connect?
A: In your settings...in your data...you have to activate the data
07-13-2021 08:15 PM
@huffy47 wrote:Before I put in the sim I reset it to factory settings,again the phone and texting works,nothing else,no google or app store,it say it's not connected,manually just did this,still nothing,quiting time is coming soon,yes I know it's me but I've done this before and never ran into this,it will not pick up the internet.
@huffy47 are you able to post a screen shot of your APN settings?
07-13-2021 08:15 PM
Yes
07-13-2021 08:14 PM
@huffy47 yours is a dual SIM phone, right? did you choose the proper sim slot for data?
07-13-2021 08:09 PM
@huffy47 did you try select 3G ONLY for your network?
07-13-2021 08:06 PM
07-13-2021 06:35 PM
@huffy47 : I hate to lose too. That's why I get a little huffy when people rant and rave and don't want to let us help them.
07-13-2021 06:34 PM
@huffy47 wrote:I have the second card here,they send 2 and actually bought another 500GB package,I hate loosing and had a smoke and a coffee and I'll sit here all night if I have too,the new card is the same,the phone works fine,out going and incoming calls,the texting works BUT not with a picture,and when I press "browser" nothing no connection,that's where I am and yes I know it's a cheap little phone that's all I need to travel with,it's a Soyes xs11,it's not on the "compatible" list but it clearly is or the phone would not work,sorry for my last messages but it's now 6 hours of this.HELP LOL.
Did you try a Network Reset of your phone Settings (if this phone has this...)?
Check the APN settings:
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
07-13-2021 06:34 PM
@huffy47 Thanks for coming back!!!
So, Wifi is working?
What is your APN settings? This is the PM APN , please check.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
07-13-2021 06:29 PM
Hello @huffy47 ,
Sometimes a break and a walk-away is a good thing. 😊
So, it sounds like you activated another SIM card though the activation process? This means you would have been $25 x 2?
Just so you know, you could have had the Public Mobile Moderators swap that new SIM card on your first account, and you would not have had to pay for another plan.
Because you are having a difficult experience today, perhaps the Moderators can cut you a break? Explain your issues (I would mention the activation problems issue that was happening today), and maybe then can close one account and put those $25 funds onto your new account.
To contact the Public Mobile Moderator_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
07-13-2021 06:23 PM
07-13-2021 06:01 PM
.. wont be Chatr, Chatr has the best roaming option out of the 3 Tier 3 .. it can basically roam where Rogers can roam
07-13-2021 05:42 PM
@softech : My guess is he was with the Rogers family. But I guess he's gone now.
07-13-2021 05:30 PM
@huffy47 wrote:Worked fine with my other provider they just don't have USA Roaming so I got Public,cheap phone yep,cheap **bleep**ty company also,this Publics is a joke man,I'll be up and running with Bell tomorrow and all set,complete garbage company.
Sound like you came from Lucky because of it lacks Roaming, now you are giving your money back to Bell again? Lucky Bell!!
07-13-2021 05:27 PM
@huffy47 sound like it is a phone setup issue instead of PM.
You said your friend is using the same phone and on PM as well? You should have try his SIM on your phone and try your SIM on his. Also, you should check the APN setup with his and see what need to be changed.
I know you are tired an want to port the number out again, but you do need to setup the SMS first so you can receive the text to approve porting out.
Maybe stick here a bit longer so we can help you to get this phone setup?
07-13-2021 05:12 PM
I can see how this all was extremely frustrating, especially starting with a temporary down activation site this afternoon.
Sorry to hear about the loss of you SIM card😥
My next trouble shooting was going to ask if you phone is locked to its previous provider. If so, that provider should be able to unlock it for you.
You could test this by putting your friend with a PM SIM card (or different provider than ur last one into the phone).
But, it seems you may have had enough since the sissors already came out.
Goodluck and safe travels.
07-13-2021 05:02 PM
@huffy47 : And for some more salt...if you ported your number in and now want to port your number out...there're no pro-rated refunds here.
07-13-2021 04:56 PM
@huffy47 wrote:Problem solved,I took out the sim card to do the reset and said screw it,I cut it in 2 with scissors or I would be playing around all night,this Publics mobile is a complete joke,I'll be set up with Bell in 3 minutes tomorrow,garbage company.
You cut the wrong thing in 2,,,shoulda cut that phone (?).
07-13-2021 04:51 PM - edited 07-13-2021 04:54 PM
Geez have some patience....your phone is only compatible with the 3G network . You would have issues with most other carriers becausr they use the 4G LTE network for talk. PM does have text/talk and data on the 3G network. These are your specs...
07-13-2021 04:50 PM
@huffy47 : Looking forward to your gloating reply here when you're all set up and working with Bell. You can't compare Bell with here. Go try Lucky and see what happens. That phone would probably be good with the Rogers family though...for a while.
07-13-2021 04:49 PM - edited 07-13-2021 04:50 PM
@huffy47...wait until you get to US and get a cheap phone with 30 day plan at Walmart. (Tracfone)
07-13-2021 04:46 PM
07-13-2021 04:43 PM - edited 07-13-2021 04:44 PM
@huffy47 : No it's not. Your phone's an obscure el cheapo foreign thingy with limited capability. Please do report back with your successes at Bell.
07-13-2021 04:41 PM
07-13-2021 04:40 PM
@huffy47 wrote:No tests in or out my friend tried to test me,I was on another provider for a month with this phone it works fine but they don't have a USA roaming option is why I went with Public,nothing works but the phone.
Put the PM sim from friends phone, in yours to see if the phone will actually work.
07-13-2021 04:40 PM
@huffy47 : If you're able to call in/out then texting should work. Outbound texting would need the proper SMSC number set up.
But without data capability on the phone, no picture messaging, no browsing.
07-13-2021 04:38 PM
07-13-2021 04:38 PM
@huffy47 : You found some obscure phone from somewhere that is barely compatible with this place and that's the fault of this place?
Picture messages require data on the account (though doesn't consume it). I'm not sure if HSPA data is included with WCDMA. But if your friend says it works then fine. Where is your friend? If you're in MB then you might be in trouble.
07-13-2021 04:34 PM
Thats excatly what I have been sitting here 5 hours doing,finally got the paln bought and the phone works,now I try to send a test and nothing,then a text with a picture,nothing,so I tried the browser,says I have no service,so I figured I'd try here because BELL is closed,seriously I'll take it there,hand it to them and a 18 year old kid will have me up and running in 3 minutes.
07-13-2021 04:33 PM
@huffy47 : That phone is pretty light for frequencies needed here. How is the reception for your friend where you are?
How about calls in/out? Texts in/out?
