09-21-2022 09:16 AM
My plan was renewed this morning. I am able to make calls and occasionally receive a text but have no data showing on my phone and unable to connect to anything. I have restarted phone several times but no luck . I know it takes some time but never has taken this long. Please help.
Thanks
Service
09-21-2022 11:09 AM
Yeah. That is unfortunate but could not figure out what else to do to correct problem. Thanks
09-21-2022 11:00 AM
The side effect of doing that as you'll discover is losing saved wifi connections and paired bluetooth devices.
09-21-2022 10:54 AM
Thanks for your help. The chatbot suggested i reset network settings and that worked.
09-21-2022 09:21 AM - edited 09-21-2022 09:22 AM
@seanhandregan any chance you have a scheduled plan change for this renewal?? There have been some major issues with plan chmagr on renewal Ray for the last couple days. Not sure if you are affected
please also try to reseat the sim card (power off, take sim out for a min before putting it back in). And you have another phone around, put your PM sim there to test
if all fails still, please open ticket with PM support
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
09-21-2022 09:21 AM
Do you see available data on your account?
Did you try to use PM SIM on other phone?
Maybe it is a matter of timing; give it few more hours and try again (reboot). Sometimes PM is sluggish to give full service after renewal.
