05-24-2026 11:45 AM
05-24-2026 12:41 PM
Sometimes, if you turn on airplane mode, then wait 1 minutes, turn back on and reboot the phone, sometimes this helps.
Another question would be, what phone are you currently using? There may be issues there since 3G is being shut down across Canada and you may be affected.
05-24-2026 11:50 AM
Make sure you don't have any data limit enabled on the phone
Reboot phone and Reset network settings
if you have physical sim, test it on another phone
if you have esim, you can actually use the PM sim to get a replacement esim for free and it should resolve the problem
but if you need PM to check first, please open ticket
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
05-24-2026 11:47 AM - edited 05-24-2026 11:47 AM
Reset the Network setting on your phone and reboot your phone…see if that works.
This happens a lot when I was with (Shaw) Rogers.
