06-07-2025 02:30 PM
Iphone... phone calls work, messaging works. No Data. Log in to PM app, receive code, enter it, nothing happens, times out after 5 minutes. On computer I get in, data usage has been at .6 for over a week now. Powered off, and powered Took sim card out, then installed, same issue. Cellular data ON, Roaming ON. Tried loading youtube app, wheels been spinning for 20 mins. any ideas ? Thanks
06-07-2025 06:49 PM - edited 06-07-2025 06:51 PM
where are you at? selected area have some mobile issue (like Kelly Lake, AB, Vaudreuil, QC)
https://www.telus.com/en/bc/outages
and voice calls work? are you new subscribers or you changed phone?
make sure you have the latest Carrier Profile, and then click Reset Network Settings and test again
Also, try changing then network mode to 4G or LTE (instead of 5G On or 5G Auto) as there has been some 5G degrade in some area
if you still cannot get any data, ask PM support to check and reprovision the account on the system, please open ticket with PM support:
06-07-2025 06:41 PM
iPhone XS Max, yes it is on
06-07-2025 06:23 PM
tried it a couple times, no data
06-07-2025 03:09 PM
With iPhones, no need to adjust APN settings.
Try a network reset of your phone. Note: this will erase any saved Wifi passwords.
06-07-2025 02:52 PM
Confirm these settings.
Settings > Mobile Networks > Mobile Data > APN
06-07-2025 02:46 PM
Any chance to try your sim card on another phone?
And call 1855-4PUBLIC from another line and the system will tell you if your account is active, which likely is, and the amount of data left, which could be the issue
You can also check if any data outage in your area
06-07-2025 02:39 PM - edited 06-07-2025 02:48 PM
@Vman wrote:Iphone... phone calls work, messaging works. No Data. Log in to PM app, receive code, enter it, nothing happens, times out after 5 minutes. On computer I get in, data usage has been at .6 for over a week now. Powered off, and powered Took sim card out, then installed, same issue. Cellular data ON, Roaming ON. Tried loading youtube app, wheels been spinning for 20 mins. any ideas ? Thanks
Which iPhone do you have?
And I know this will sound silly but... go to Settings > Cellular, then turn Cellular Data on ?? I ask this to CONFIRM it's actually on. Even though you said it, I just cover my bases cause there have been times people think it's on but it wasn't. 🙂
