09-23-2025 11:40 AM
I have a new phone S25 Android. It appears Telus has blocked access to data. Phone calls work as do text messages (text only).
09-23-2025 08:32 PM
are you sure both voice and text are working?
if only data is the issue, make sure you are using Public Mobile APN and not Telus.
And I suggest you to compare the following and update accordingly:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D (or try: 4D4F)
09-23-2025 07:43 PM
Tried this, still no data access. Trying to find out if phone is compatible with Public mobile network.
09-23-2025 11:56 AM
hi @1957Squire
Telus won't block data, you might simply need to Reboot phone and Reset Network Settings
