No Bonus Data with Autopay
winson0228
Hi,
I started a $15 plan WITH autopay on PM for my grandpa recently. The data isn't working on his phone. The plan says there is a bonus of 250MB 3G data but I'm not seeing 250MB anywhere under Data and Add-ons on his account. Please help!
Thanks
13 REPLIES 13
All plans that include bonus data for setting up Autopay have that amount of data included in the plan each month. Larger plans have 1/2 Gb bonus data but just 1/4 Gb on the $15 plan.
AE_Collector
lynsay
Not just one time.
@PaulSta wrote:
$15 plan: "Bonus 250 MB Data⁴ at 3G speed with AutoPay" 1 time or every month bonus?
@PaulSta
Every 30 day cycle.
PaulSta
$15 plan: "Bonus 250 MB Data⁴ at 3G speed with AutoPay" 1 time (until used) or every month bonus?
@winson0228  You may want to go thru your grandfather's phone and enable his data saver and data tracker. Restrict the background data use in all but the most important apps.
pmmobile
@winson0228
You could also check the usage history in self-serve to see if it has been infact used up, or that it is missing.
If you claimed the 1GB holiday data bonus, then as already mentioned, unless you used that up as well, it should still be there along with the 400 LD international minutes.
It may be a better idea to clear it up now and it does not hurt to send a quick message to the mods because you wouldn't want to find out it's a glitch on your second month
dboxtvinfo715
Of course we have 250 mb, with autopay, and email me if you need help
@AE_Collector wrote:
The 400 minutes Christmas gift is there but not the 1Gb data gift. So, more than 250 Mb may have been consumed, 1.25Gb is potentially gone.
AE_Collector
hmm Indeed. @winson0228: did you also pick up the data gift when you got the 400 gift?
Maybe data mode was inadvertently turned on and the phone gobbled up all the data with updates and such. 250mb isn't a whole lot for a phone to gobble quickly. But 1.25gb is a chunk of data.
AE_Collector
@winson0228 wrote:
I'll check the account again once the plan renews. I did not know that it disappears after it is all used. Thank you!
You can check in the phone network/data settings and it should tell you how much you have used up.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
winson0228
NDesai
@winson0228 I just checked one of the account i manage and the 250MB data is showing up right under the 100 min Canada-wide talk add-on. It seems like something gone wrong with your activation. You will need to reach out to the mod team so they can investigate. Start a conversation with Simon (chat bot) by clicking HERE to submit a ticket to the Moderator Team. Be sure to provide as much details as possible so the bot can enter all the info needed to open a ticket.
EDIT: forgot that addons disappear after you use it all up. See the response above.
@winson0228 wrote:
Hi,
Thanks
Seems you've used it up for this term. It should renew.
