Nexus 5
GEMINIMAN2005
Hi
My nexus 5 wifi stopped working after installing PM sim. Wont connect to wifi any more. Any suggestions.
gblackma
@GEMINIMAN2005 do the network reset as suggested by @gpixel  and use the following APN settings. Which Nexus 5 ? Google or LG?
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
iliketotalk
@GEMINIMAN2005 Take your sim out does your wifi work now?I would be very surprised if it did
Staliger
@GEMINIMAN2005 Issue is either with your phone or its software. Sim can't block your WiFi.
@GEMINIMAN2005  A sim card can't make your Wi-Fi stop working. Public Mobile doesn't block Wi-Fi usage. This would either be a device or software issue.
gpixel
@GEMINIMAN2005 reset your network settings
I'm not sure which android version you're on but it should be similar
open settings
scroll down to system
tap on reset options
tap reset wifi,mobile & Bluetooth
tap reset settings and restart
popping
@GEMINIMAN2005 wrote:
Hi
Turn off your phone for a minute.  Then, tune it back on and let PM SIM card to configure your phone.  Report result.
