Did I purchase the correct minutes?
kennzo
I noticed that I was using more than my usual # of minutes in local calling , so I purchased what  (I believe)  to be more minutes to use before the end of my 30 day  plan.
I could not see any 'local' minutes on the add on's page,  so I purchased  500 canada-wide long distance minutes.
I now have lots of Canada -wide long distance and lots of us-Canada long distance
If I run out of local minutes prior to my 30 day renewal , will these minutes that I bought allow me to continue to use the phone??
If not, please tell me what add-on/option to purchase so that I can continue local calling
Thanks
1 REPLY 1
Jb456
You're good with the $5 500 minutes Canada wide add-on.
Take note the $5 Canada wide add-on does not include USA. Unless you bought a 200 minute USA/Canada add-on or a 400 international add-on as well?
It will continue to rollover every 30 days until all used up.
Once you deplete your minutes from 30 day plan then the add-on will kick in. Once your plan renews it will go back to plan minutes then add-on will kick in if you need again.
Have a good day!
