Newly joined
ShannonZL
Hi,
I just switched onto public mobile. I can make outgoing calls and use data however, I'm am unable to receive incoming calls or send/ receive text messages.
@ShannonZL
I already sent before you asked 🙂
@Shidong  Sent !
Shidong
Can you also send me the number. I been stuck here for the whole night. Thank you!
slusagm
@ShannonZL
there is a porting assistance team you can call and ask for update.  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link
 And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
@ShannonZL  There’s live support for porting issues will send it to you private message as we not allowed to post it here
if they will not help you can message support to help with this
send  a  private message   To CS_Agent
