New to public mobile
09-08-2020 10:50 AM - edited 01-05-2022 03:48 PM
When purchasing my sim card for this company I was told to be careful as I may not get reception In my area is this true I live in blind river ontario
Payment
09-08-2020 11:30 AM
@Lilybouchard84 yes this is true, there isn't much reception in your area.
https://www.ertyu.org/steven_nikkel/cancellsites.html
(the blue flags are bell/Telus and the red flags are rogers)
If you decide to go with public mobile, I highly suggest purchasing a cellphone booster to increase reception.
or
go with I higher tier company with "volte". lucky mobile has wifi calling. so if your reception isn't that good you will still be able to use wifi to make and receive calls using Lucky's app
![](/skins/images/DCE4DBC5FB75F667235A257F9030739A/responsive_peak/images/icon_anonymous_profile.png)
09-08-2020 11:03 AM
@Lilybouchard84 You can check the following interactive map (use Bell & Telus). I think you are good to go.
https://www.comparecellular.ca/coverage-maps/
09-08-2020 11:02 AM
You should be just fine - the coverage map shows that there is service coverage for Blind River, ON.
Coverage map can be found here: https://www.publicmobile.ca/en/on/coverage
09-08-2020 10:52 AM
@Lilybouchard84 wrote:When purchasing my sim card for this company I was told to be careful as I may not get reception In my area is this true I live in blind river ontario
@Lilybouchard84 hello as long as there is a bell or telus tower nearby you are good to go 😁
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
