New to Public Mobil
WesH
I made the switch to public and ported my number over from my previous provider. Under settings, I’ve switch to the Public Mobil E sim.  I'm able to make calls, but I'm not receiving incoming calls or texts.
Am I missing something?
10 REPLIES 10
dust2dust
Ah jeez. @Lucian_G - Never ask for information from customers out here in the open forum. Always use private messaging.
@WesH- Good. Now follow the instruction at the bottom of the reply from the other member to reply to the agent in private messaging (if you haven't already figured that out 🙂 ).
WesH
Thanks
@CS_Agent wrote:
Hello@ WesH
Lucian here and thank you for reaching us! I will be more than happy to assist you today!
In order to start the investigation would you please provide us the e-mail address that you
register with us and also the phone number that you want to port and the account number
of your Old Provider.
Regards
Lucian CS_Agent
@WesH
add to Lucian/CS agent message, please provide them the information via messaging @CS_Agent here:
CS_Agent
Customer Support Agent
Hello@ WesH
Regards
Lucian CS_Agent
WesH
Thanks for the private msg. I call the number, and there is no record of a transfer request for my number.
Your previous provider will send you a text confirming you... the account holder... are porting out your number. You will need to confirm before your previous provider signs off on the transfer.
WesH
Thanks for the reply.
I’ve left the SIM card in the phone.  It’s been less than 90 minutes. I’ll wait a bit longer.
What do you mean by “confirm the text”?
@WesH  Sorry just re read your post sounds like it stuck in port . There’s a number to call live support to fix . Will send you it private message . As we not allowed to here
dust2dust
It sounds like you didn't leave the old sim in a phone to confirm the transfer. If it was less than 90 minutes ago then do so and confirm the text.
@WesH  Have you rebooted the phone ? Try resetting network settings . If still no dice . get support to re provision sim. For you
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
