New subscription
Maddog2130
Connected to public Mobile yesterday but can’t send or receive calls or texts. Why is that?
2 REPLIES 2
Maddog2130
Data does not work. I still have my old SIM card. I kept my same phone number from my old carrier
Dunkman
@Maddog2130
More details would be helpful.
Does data work?
Did you port over a number to Public mobile?  If you did port, did you respond "yes" to the port request text from your old carrier?  Did you remove your old carrier SIM card? or inactivate old carrier eSIM?
