New subscription minutes used up
Babkat
My plan is new since late yesterday, barely used any data, but can’t make a phone call because minutes are used up. Not sure why!
7 REPLIES 7
@Babkat   Probably best to contact customer service, send a private message to them using this link
An agent will reply at the envelope icon top right or tap your avatar for Messages if no envelope.
Babkat
Reboot didn’t work.  Have unlimited minutes, $102/90d
Babkat
I have unlimited minutes, $102/90d
Babkat
I have unlimited minutes, trying to call within Canada, $102/90d. Is it an issue with the eSIM?
@Babkat
Are you on the $15 plan?
Try login to your account and check the amount of time used on your call history. Remember that minutes are rounded up so if you make a call that is 5 minute and 1 second…it will be rounded up to 6 minutes.
Also try rebooting your phone by powering off then back on to see if that helps.
hairbag1
@Babkat
all except the $15 plan include Unlimited Canada wide calling. If you have the $15 plan you get 100 minutes of outgoing call to Canada but unlimited incoming. Which plan do you have ?
edited...
you can either upgrade to $25 plan with Unlimited Calling in Canada OR buy the 500 minutes of Canada wide calling add-on for $5.
Phil_Adelphus
@Babkat   Only the $15 plan has limited minutes (100 minutes).  Are you trying to call within Canada, otherwise you will need to buy an add on if calling another country.
