a month ago
I recently switched to public mobile and now I cannot call anyone in my area (705). My phone has a 416 area code
a month ago
Hey @PatnGary57, are you able to receive calls, send and receive SMS text messages? These would be basic steps for confirming your service is working.
You will probably need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
a month ago
HI @PatnGary57
also try calling without the 1 then. (yes, it is confusing)
and can you call other area codes? like 905?
a month ago
I do put a 1
a month ago
