05-28-2023 10:46 PM
If I subscribe to this new promo can i keep my rewards?
The new promo is $39 for 20 gb / monthly
05-28-2023 11:05 PM
Thank you 😃
05-28-2023 10:51 PM
@Anatinay Changing plan won't affect rewards. So, no worry, go ahead and make the plan change. Just make sure you use Change on renewal if you don't need the extra data urgently
05-28-2023 10:50 PM
05-28-2023 10:49 PM
HI @Anatinay Yes, you keep all the rewards and same rewards system after any plan change. My family just change plan and yes, keeping the rewards
05-28-2023 10:48 PM
Yup, your rewards remain unaffected by plan changes, unless it's a specific promo that states it doest not transfer.
