03-08-2024 09:27 AM
I have a new plan and in my settings my ported number from Fido is the right number. I set up two days ago and can receive and send texts. I can call out. However I just realized all my calls are going straight to voicemail. I ensured call forwarding was not on, I do not have Do not disturb on, no airplane mode on etc. I also turned off phone and restarted, and then I did the same taking the sim card out. Any ideas??? Seems to be a porting issue, but I am happy to try new things while I wait for support.
03-08-2024 10:17 AM
Thanks - I called the Porting team and got it resolved. I did not answer YES in time from Fido so they had to resend a transfer request. I answered YES right away and number should be fully ported shortly. Was only receiving texts from Telus customers and imessaging I realize now.
03-08-2024 09:39 AM
hi @SJoan
Did you get a text from the old carrier, did you reply YES?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
