New offer
Kin1
I just received an offer of 15G for $40.00, how long is this term last?
LeePublic
This is a hot 🔥 deal, unless you are a low data user or an cheapskate, you should jump to this plan immediately!
dabr
@Kin1   Nobody knows, it could last several weeks or be removed any day.  Log into your account, select Plans/Add-ons and schedule Change at Next Renewal if interested.  Make sure to select the correct $40 plan as there are two with the same price.
edit:  yes the data allotment will be available as long as you keep the plan.
Outdoorsman
@Kin1 hi it is supposed to be permanent but not sure how long it will be offered so don't wait to long if you want it
JK8
@Kin1
This is permanent until you decide to change plans.
