New number
09-18-2017 04:21 PM - edited 01-04-2022 02:38 PM
09-18-2017 09:19 PM
Please carefully look at the page where you can select a new number.
Sometimes it just shows you a couple of numbers but there is an option to choose from more numbers. Once you select that option, you maybe able to see more numbers and perhaps a 647 number.
09-18-2017 05:25 PM - edited 09-18-2017 05:27 PM
As mentioned in the thread about the same issue that you started yesterday, your only other option is to contact contact the @Moderator_Team and ask nicely if they would be willing to look into the pool of available numbers for you.
If you are unsure on how to go about it:
09-18-2017 04:32 PM
I wanted a 647 number they don't offer those there
09-18-2017 04:30 PM
you can change your number in self-serve. Under "My Plan & Add on" there is a banner for Change phone number
