New line does not work after activation
Thorpe
I just activated my line but it is not working, showing SOS. what am I missing. Money has been taken from my account and I have a phone number.
Thorpe
Thanks, I have created a ticket
@Thorpe if it does not even connect,  it is likely a dom provisioning problem
First,  try to either reseat the sim card or try on another phone of you have one around
if it is same, then you will need to open ticket with PM and they can reprovision the sim
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
Meow
f you did not port your number at the time of activation, check your account to see if it is Active.
Reboot your phone - turn it off, wait few minutes, turn it on.
HALIMACS
@Thorpe
The most common fix for this is to do a re boot of the phone, or reset network connections, or toggle airplane mode on and off.
If available, you may also want to try the Public Mobile SIM card in another known working device to see if calling features work.
If you were porting your number from another provider, did you reply "yes" to the port authorization request from that provider after the activation?
