New customer
Cveltski
I cannot receive incoming calls. I requested a number transfer and my previous provider virgin prepaid said they have not received transfer request from you yet. I set up my new account with you two days ago.
2 REPLIES 2
@Cveltski
A critical part to porting is to receive a text from your old provider and reply YES within 90 mins.  Sound like you missed the step and hence porting was not completed
There is a number to all to talk to live support and the can re-trigger the process for you.  I will message the number to you via the Community inbox.  Check the envelope icon on top right.  Call them and get it fixed
MrSpock
@Cveltski Hi since it is prepaid it may be best to reach out to a cs agent you will need to open a ticket, to speak to a customer service agent    Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
