New activation
01-11-2024
12:38 PM
01-11-2024
04:03 PM
computergeek541
Hello,
I am working on a new activation. I have selected my plan and now debating on an eSIM or SIM card. I prefer the card to be able to move from phone to phone should something happen but when does the plan kick in? It wouldn’t transfer my number right until I got the card? For the sake of quicker activation the eSIM is appealing. Can I later transfer the eSIM to a card?
thank you!!
Joining Public
01-11-2024 01:34 PM
I missed the special for the cards. They are $5 and $10
01-11-2024 01:33 PM
Oh goodness! Thank you!!!
amd the eSIM is instant right while I can keep my current number
01-11-2024 01:32 PM
That sounds like a plan. Thank you.
I missed the deal with the free SIM cards so they are now $10 and the eSIM is $5
01-11-2024 01:31 PM
Okay that sounds good. I think I would rather the eSIM right away rather than wait for the physical sim and have the money tied up while waiting for the sun as I have to pay up front for the plan.
thank you!!
01-11-2024 12:47 PM - edited 01-11-2024 12:48 PM
@Mi21 Yes you should be able to start off with esim and then switch to a physical sim later. Or you might just want to leave it on the esim once you've set it up and keep a physical sim in case you need it later. You would have to pay the going rate for the physical sim. Edited to say it looks like the esims are not free any more?
01-11-2024 12:45 PM
@Mi21 The plan kicks in once you activate the sim . And you. Need the APP to activate But you can always change back to physical sim card in your account profile page and sim swap the number
SIM SWAPPING profile tabs
Note only do this on lap top or computer/ not mobile device
01-11-2024 12:43 PM
SIM is the way to go if you want to switch between devices.
Both are free now with new activation.
Yes, you can switch to eSIM later. Just login to your account and make a purchase of an eSIM and it will transfer your account information to the new eSIM.
