New activation not working
Redline22
Hello, I've been trying to activate a new Sim card, but it keeps saying information is incorrect at the payment screen. Is there an issue with the site?
You're sure you're entering the billing address postal code of the credit card? Not the new customer (if not you)?
@Redline22
Yes, a CS_Agent can help you activate your SIM.
Redline22
I've tried 2 credit cards and a debit Visa, all good standing, didn't work.  I've tried on 2 different computers and mobile and different internet sources since last post, nothing worked which points to something wrong with the site.  I've started a ticket to do a manual setup with an agent.
@Redline22
If you are using a voucher, it can’t be done online. You will need a CS_Agent to help you complete the payment section.
HALIMACS
@Redline22
Are you using a Canadian-issued credit card or a visa/mastercard debit?
Try using a desktop or laptop device.
dabr
@Redline22    Just to clarify, this is a new activation and not a SIM change?
If it's a new activation, first check to see if your card has been charged.  If there's no pending charge on the CC then retry the activation again using private/incognito mode or another browser.
If you still encounter issues, then contact support by submitting a ticket via chatbot here:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If unable to submit a ticket, then send a private message to CS_Agent here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
