08-26-2018 01:56 PM - edited 01-05-2022 12:40 AM
Hi,
I signed up for PM yesterday and haven't left the house since then (I've been on wifi since then). IE: 100% of my data usage has been on wifi. Today I received 2 SMS messages within a minute of each other stating that I had used 75 and 95% of my usage respectively. I checked my account which states that I have used 0.1 MB of 3G data.
What gives? Do I just assume that usage SMS from PM are incorrect?
Thanks!!
08-26-2018 03:44 PM
Yep, just as you suspected, data has been cut off after 12MB. Not a great first experience with PM.
I have sent the mods a direct message. Thank you!
08-26-2018 03:22 PM
Yes, I'm an iphone user, but wifi assist has been turned off.
However, I would imagine that even if wifi assist were on and if it were using data, it would still show up as data usage.
08-26-2018 02:38 PM
@crossix, do you happen to be an iPhone user? iPhones have this wifi assist feature that can consume data even when connected to wifi. This may be the reason for the data leakage.
08-26-2018 02:08 PM
@Dunkman wrote:Welcome to Public Moible.
I would go with your usage history from your self service account. Probably a glitch in the system with your SMS texts. Just monitor for the next day or so. Everything should be fine.
However, if your data cuts off, immediately send a private message to the moderator team and have them correct this for you.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
08-26-2018 02:07 PM - edited 08-26-2018 02:09 PM
Sounds like glitch. But for peace of mind, it’s not a bad idea to disable all background use of data for your apps, allowing only specific apps as you please. You can also keep your cell data turned right off most of the time, to avoid operating system drains. (It can happen, even if the settings are locked down).
I noticed my self-serve account actually changed data use amounts, dropping back several mb (perhaps fixing mms use vs. actual data use.) Keep an eye on your account, though, and maybe note down what’s recorded, just in case it goes crazy and you need to contact pm moderators.
08-26-2018 02:00 PM
