3 weeks ago - last edited 3 weeks ago by computergeek541
New points system - Can you buy multiple $15 credits to apply to your bill in the same month if you have points? Or is it one $15.00 credit per month?
Also how smooth is the transition from SIM to eSim?
M
3 weeks ago
3 weeks ago
E-Sim is device specific, yes.
When changing devices, a new e-Sim is required to be purchased and installed on the new device.
A physical SIM can be moved from device to device much like the old SD cards could be.
I prefer the old SIM personally, however it’s personal preference.
3 weeks ago
So eSim are not transferrable? I understand that whenever you switch a device, you will have to change eSim each time?
3 weeks ago
$5 to switch to eSIM on the app unless you initially register as eSIM when switching to public.
You can apply as many credits as you’d like as long as you have it! Might be applied to the next months bill though
3 weeks ago
Why switch from physical SIM card if the physical card works?
They can be switched from device to device when changing/upgrading devices. E-SIM cannot.
Only hitch would be if you acquired a device which is e-SIM only...
3 weeks ago
I was thinking of switching - i am hoping it will be a smooth transition
3 weeks ago
Thanks for the quick reply 🙂
3 weeks ago
Transfer from SIM to eSIM is easy, but you need to buy eSIM from the app for $5.
3 weeks ago
You can redeem 15 points for $15 multiple times as long as you have enough points, all credits would be applied to the current month.
