06-24-2020 05:46 PM - edited 01-05-2022 11:50 AM
Blu have just announced a new phone which looks like good value and decent specs for the price. Priced at USD150 or promo right now at USD100, I wonder what it will cost here?
Full review here: https://www.reviewgeek.com/46019/blus-g90-has-a-big-screen-and-triple-cameras-for-150-or-100-if-you-...
06-25-2020 05:19 PM - edited 06-25-2020 05:20 PM
The G90 runs a MediaTek Helio A25 octa-core processor, 4GB of RAM, and 64GB of storage, and additional capacity in the MicroSD card slot. It is a dual-SIM phone with a 4000mAh battery. It also has a rear-mounted fingerprint reader rather than the problematic under the screen version that others have tried. It also has a triple rear camera array: 16MP main shooter, 8MP wide angle, and a 2MP depth sensor. The front camera is 13MP. And it runs Android 10. Fit and finish appear good as well.
All decent specs, IMO and as good, on paper at least, with phones double the price.
I see last years G9 model listed for CAD400+
Now if only I could find a retailer that carries it 😁
06-24-2020 07:29 PM
@Naepalm wrote:Specs on it look respectable and android 10 out of the box. hmmm.
How long do budget phone last usually?
Depends on the model, of course.
Budget phones are designed around a price point. So usually tech one or two generations behind plus one or two bolt-on Impressive Hardware Features like Huge Screen, Great Camera, or High Grade Music/Audio. The Impressive Hardware Feature(s) tend(s) to suck the battery dry pretty quick, and Big Screen means Big Form Factor with Big Battery ... but it tends to be something "cheap" with low energy density so about a year before it rapidly loses ability to hold much charge.
I've used a bottom-end SKY, a bottom-end RCA, and a bottom-end Huawei. All of them had clunky software and bloat. All of them ended up refusing to hold charge for more than half a day of idle after about a year. All of them promised 16GB (or whatever) of storage but in actuality started to complain and malfunction after less than a few GB were actually filled up.
I think the trick is to only buy the low-end when you urgently need a cheap working phone right away, but then plan on getting something better within a few months. If you hang onto these things too long they're just going to frustrate and junk out on you when you need them most. (I only bought them when I needed a "temporary" "disposable" sort of phone which I expected would get destroyed at heavy industrial job sites, lol, but alas it seems I've become too careful with them so they actually don't get abused and wrecked as quickly as expected.)
06-24-2020 07:13 PM
BLU G90 supports the following bands according to https://www.gsmarena.com/blu_g90-10313.php
3G bands | HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 |
4G bands | 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 28 |
850 MHz | Band 5 |
1700/2100 MHz | Band 4 |
1900 MHz | Band 2 |
2600 MHz | Band 7 |
3G 850MHz, 1900MHz
This phone should works with PM.
06-24-2020 07:11 PM
Thanks for the info, but I think better buy big company's products, like Samsung etc.
06-24-2020 07:02 PM - edited 06-24-2020 07:05 PM
looks good I am not familiar with blu personally I wouldn't buy it because I am not familiar. But I'll look into it. Thanks for sharing.
cheers
