New Activation
11-29-2022 01:46 PM
I just activated a new sim card and transferred my phone number from Telus. My telus account is now deactivated, but when putting the new sim card in my phone, it shows SOS
Joining Public
11-29-2022 04:26 PM
I had the same issue. I connected with support via private message and they were able to resolve it fairly quickly!
11-29-2022 03:32 PM - edited 11-29-2022 03:33 PM
I was having the same problem today with 2 different phones, the port seemed to be complete and the old service was deactivated but I had no service with my Public Mobile SIM.
If you have an iPhone, go to Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings.
My PM service started working after the phone restarted. I hope this helps someone else struggling with this problem!
11-29-2022 03:02 PM
Exact same issue you described. This is absolutely ridiculous I have zero phone service my telus line is disconnected they said the port completed and Public is not working. I messaged CSA they said an error occured on the port process on their part and that it will take a few hours to fix. I was expecting some very important calls unacceptable
11-29-2022 02:35 PM
I have the same issue on two phones we moved over
1 phone has service but the number we ported cannot be called. (just outbound calls work)
The other phone has no service as well even though porting worked (just shows SOS). The CSA agent said there was some larger technical issue but it's been about 14 hours without service on these now
Not a good first experience moving to Public Mobile 🙂
11-29-2022 02:14 PM
Hi @hycm53 SOS usually just means your sim card cannot connects to the network
@Colinmac You came from Telus, did you get this phone from Telus? did you pay the phone in full?
sometimes if carrier blacklisted the phone, it will show SOS as well as the carrier rejects the connection request from the phone
11-29-2022 02:09 PM
@hycm53 SOS means the ship is sinking and you need help , right away!
From a CSA agent.
11-29-2022 02:07 PM
What does mean "SOS'?
11-29-2022 02:05 PM
@Colinmac wrote:I just activated a new sim card and transferred my phone number from Telus. My telus account is now deactivated, but when putting the new sim card in my phone, it shows SOS
11-29-2022 02:00 PM
According PM website :"The number transfer process can take up to 2 hours to complete for a mobile phone number."
HI @hycm53 but if OP's Telus line is already deactivated (assuming OP didn't do anything to manually cancel it), that would confirm the porting is completed
Also, even porting not done, OP should be able to connect to the network and make outbound calls, it should not show "SOS"
11-29-2022 01:59 PM - edited 11-29-2022 02:00 PM
@jimau Sim card still needs to be set up with connection to PM.
Get help from a PM CSA agent right.away.
11-29-2022 01:59 PM
HI @jimau sim not provisioned means it is not setup properly on the system
please open ticket with CS agent. only they can fix it
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
11-29-2022 01:58 PM
11-29-2022 01:57 PM
I’m getting a message in my phone saying sim not provisioned, anyone have any idea what that means?
11-29-2022 01:56 PM
HI @Colinmac if you have another phone, try the sim card there
and you didn't chargeback on Telus or PM charges thinking that is how to cancel your Telus account?
If you are still getting SOS, then open ticket with CS Agent, maybe a sim card setup problem on their side
First type Contact,
11-29-2022 01:56 PM
11-29-2022 01:53 PM
Same here, I gave Telus a call, they said the numbers have ported but not sure why public has no service
11-29-2022 01:52 PM
Yes the plan says it is active and they have taken my money. I've tried the reboot. I have also tried my sim in another phone and the same thing happens
11-29-2022 01:51 PM
We tried but didn’t work
11-29-2022 01:51 PM
I have tried that.
11-29-2022 01:50 PM
Yes I did
11-29-2022 01:50 PM - edited 11-29-2022 01:52 PM
did you reply yes first to change if so then remove old sim and put new one in and wait about 2 hours for text from PM
11-29-2022 01:50 PM
@Heidiau Try re-installing your sim card and reboot your phone
Set your network settings to automatic from in your phone settings.
11-29-2022 01:49 PM
Did you create on-line account?
Does it say service is Active and plan details?
Re-seat your SIM. Reboot phone. Try your SIM in another phone if possible.
11-29-2022 01:49 PM
I tried this but no luck
11-29-2022 01:47 PM
Same issue here
11-29-2022 01:47 PM - edited 11-29-2022 01:48 PM
@Colinmac Try re-installing your sim card and reboot your phone.
Switch network settings in your phone to automatic.
