02-25-2024
01:19 AM
02-25-2024
01:39 AM
computergeek541
I have a new phone I want to use with my existing PM account and with existing SIM CARD. My current plan is a 3G plan, my new phone is Galaxy A53 and I beleive it is a 5G phone. I put my SIM CARD in and phone does not register on the network, do I need to upgrade my subscription to a 5G to fix this problem?
02-25-2024 07:52 AM
I'm on the 3G plan with a 5G phone, I sometimes get 5G in certain locations. Make sure you switch it on in the phone's settings.
02-25-2024 02:33 AM
are you not in Canada or you are using VPN?
try accessing the site from another computer, of course, make sure no VPN is used and you are connected from Canada
02-25-2024 01:51 AM - edited 02-25-2024 01:52 AM
this is what showed up when I used that link you provided, no idea what that means because I am in NS, Canada. I checked earlier and whatever site/tool i used said that it was not blacklisted
02-25-2024 01:45 AM
did you buy the phone from Samsung or from trusted source?
check if the phone is clean first:
https://www.devicecheck.ca/check-status-device-canada/
02-25-2024 01:42 AM
@BKNS27 wrote:ou will need a 5G plan to have 5G but the Samsung phone may not indicate 5G on the phone but you can confirm by doing a speed test on the phone.
The above isn't correct. a 5G plan isn't required to use the 5G network.
02-25-2024 01:40 AM
@Darham77 wrote:I have a new phone I want to use with my existing PM account and with existing SIM CARD. My current plan is a 3G plan, my new phone is Galaxy A53 and I beleive it is a 5G phone. I put my SIM CARD in and phone does not register on the network, do I need to upgrade my subscription to a 5G to fix this problem?
All Public Mobile plans gives access to the same networks. There is no requirement to change your price plan.
02-25-2024 01:35 AM
Maybe I should of mentioned, I did restart, I did full power off, I reset network settings, I toggled airplane mode off and on, I checked and phone is not black listed, I tried to check if it is compatible on PM but their page is down when it redirects me,
02-25-2024 01:27 AM - edited 02-25-2024 01:34 AM
Reboot the phone by powering off then back on to connect to PM network. You will need a 5G plan to have 5G but the Samsung phone may not indicate 5G on the phone but you can confirm by doing a speed test on the phone.
If you stick with the 3G plan, you will be on 3G with tge 5G phone.
