Network
SimSim2023
Hello yesterday just out of the blue my pixel 6 pro quit and will not connect to public mobile network! Anyone know what I can do??
Phil_Adelphus
Have you tried turning airplane mode on, waiting a little while and then turning it back off again?  If none of the suggestions works, maybe see if you can try your sim in another phone
Chalupa_Batman
Before you reset all your network settings, just know that because Android doesn't seem to be able to just reset the Public Mobile network, it will erase all your saved WiFi spots. Work, home, restaurants and such...
@SimSim2023
Try resetting the network setting on your phone.
This could be a temporary network issue near you.  If you havent' already tried, reboot your device.  All check your IMEI status at devicecheck.ca.
