Network lost
Glen7600
I just got a new phone and got eSIM from public. Now it says network lost on a pop up. Continuous. Also my old phone no longer works.
2 REPLIES 2
Moved:
The post from 22 minutes earlier said exactly the same thing. Please avoid repeating others.
@Glen7600  Have you tried to reset network settings and reboot the phone ? I’d start with that also make sure the public mobile eSIM is set to primary and there’s no other sims in the phone . If you still have issues you can ask support to help fix for you
send  a  private message   To CS_Agent
