03-08-2026
05:12 PM
03-08-2026
08:25 PM
computergeek541
I have been unable to use data for 2 days and I can't seem to reach the Customer Service Agent. Meanwhile I was just charged for this month's subscription. I need answers as I an unable to use data outside my house.
03-08-2026 05:16 PM
@Olumight Maybe try rebooting the phone and reset network settings see if that helps , note by resetting network settings you will have to re add wifi password and blue tooth
but to engage support
Public mobile prefers
you use the orange chat bubble bottom right of screen . If that dosent work you can instead send a private message To CS_Agent
03-08-2026 05:14 PM
hi @Olumight
you tagged the wrong people. Also, tagging support won't help. You need to submit a ticket
but before doing so, try to Reboot phone and click Reset network settings. Check if the phone shows connected to the Public Mobile network
if you need to submit ticket, submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
