06-16-2023 01:49 PM
My wife cannot receive or make calls or texts. My call to her said I do not have USA roaming. We are side by side in the same room in Ontario, what is going on?
06-16-2023 01:51 PM
@Wolfiehowl This could be an indication you need to make payment . Log into her account is it active ? Or on hold
06-16-2023 01:50 PM
The roaming recording is likely a wrong one, however, with that recording, it could indicate your account is suspended. Please login My Account once more using Incognito mode and confirm your account status
If status shows Suspended, make a payment to resume service
If it shows Active, try to reboot your phone and click Reset All Networks (Please note that will delete your saved Wifi as well, but you can easily add it back after)
If that still does not work, please message support for further investigation
