Need to contact someone to help finalize porting
11-30-2016 08:08 PM - edited 01-04-2022 01:20 PM
Hi, I've been stuck in a porting loop with no way to contact PM directly. Apparently my porting was rejected when activating even though everything else appeared to be working fine. Calling fido to confirm cancellation they said i was still active with them. Just want to keep my number and move forward but havnt heard back from pm by in over a week after emailing them. When i try to port over number option in change phone number it says having trouble processing - get in contact with pm. Please help. Currently paying for two plans while this happens
Joining Public
12-01-2016 10:56 AM
11-30-2016 08:12 PM
hi..
most likely your port is denied by fido because the information you provided to PM does not 100% match with what fido has on file....( a capitol letter or having switched phones with a provider thus having a different imei number could already set up the port for failure )...
email is not the best way to contact PM...send a moderator a private message..it might take a few days for them to respond to you due to huge backlog..
cheers..
11-30-2016 08:10 PM
hi @adampellerine, I will tag @Shazia_K (clcik her name, and send her a private massage with your port ing details) account number phone number old fido account name.
use your fido sim until it gets sorted out. not sure whta the current backlog is, I know shazia was working overtime yesterday, so hopefully it is clearing up. hang in there.
