Need refund
Lorraine30
Not able to use service, and need a refund.
hI @Lorraine30
CS agent already replied, please check your community inbox and work with them.
CSA_PM
Customer Support Agent
Thank you for the escalation!
The client is already in contact with an agent, and the agent is waiting for a response from the client in order to assist further.
@Lorraine30
If you recently subscribe for a plan on PM and had issues. You will need the assistance of a CS_Agent to receive a refund or to determine the issue.
Contact them by clicking on the Chat icon and type in Submit a Ticket or dm an agent at:
We can try to help you if you can describe your problem. Did you just ported your number over to PM? Did you reply to the text from your previous carrier confirming you are porting your number?
Or did you picked a new number?
