12-02-2024 11:33 AM
I am unable to use the QR code provided in the summary email. Please help me with new Esim
07-13-2026 02:02 PM
Hello. Can I get a link to message directly to support? I am having a similar issue.
I need a QR code to install new eSIM on Samsung s26 because the Samsung won’t let me past the mobile activation step in order to download public mobile app and install the eSIM. I initially had the QR code from the first activation with you guys in my iPhone but need to transfer to the new Samsung. I started the process in the app on the iPhone to download and install eSIM. eSIM is ready to go but I did not receive an email with the new QR code and I cannot finish Samsung startup to use your app until eSIM is activated.
12-02-2024 11:41 AM
@Adithi, I believe the QR code will only work once. You can try purchasing another eSIM from the PM app but don't worry, because you already had one you will not be charged for any eSIM's going forward. Ordering one should send you a new email with a QR code to use. Or, you can reach out to a support agent to see if they can get you going.
Click on the link below to message a support agent directly:
12-02-2024 11:39 AM - edited 12-02-2024 11:42 AM
hi @Adithi you shouldn't delete it
but you can still get it back yourself. Login the Public Mobile app, use email to receive 2FA (click Didn't receive code and send eamil should be an option there). After you logged in, go to Account page and click Buy sim card and choose esim
12-02-2024 11:38 AM
I installed it once and it worked for a day and then there was no service. So deleted the Esim from my phone. Now I am no longer able to use the QR code sent in the email to activate the eSim.
12-02-2024 11:37 AM
12-02-2024 11:36 AM - last edited 3 weeks ago
hi @Adithi
can you confirm if the esim already installed? It could be installed by the app and you don't need the QR code to install.
Fisrt, make sure your old physical sim card is removed , or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
On the same Sim card Manager, or Settings->Cellular screen, check if Public Mobile esim is there. If it is , make sure it is set with label: Primary and enabled (or Turn on this line is enabled), then Reboot your phone and Reset Network settings
if that does not help, ask support agent to check. Please use submit a ticket here using the same Community login credentials you are using now: https://expert-messaging.publicmobile.ca/guest/chat/
Once you started the Chat, type "Submit Ticket", then "Connect Agent", and it will ask you to login to open ticket
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email" or "Send Voice Message")
Remember CS_agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
