01-25-2026 10:55 PM
Attempted to transfer number from Koodo. Need help to finish set up account and transfer 🙏
01-25-2026 11:09 PM
Physical SIM card, no I don't believe I made it to step 6. Never got a text from public to complete the process. The page showed failed, and I should seek support, which I'm working on 👍, thanks
01-25-2026 11:02 PM
hi @Yamest
physical sim or eSIM? did you try the sim and can you make outbound calls?
or you didn't reach Step 6 in the activation process at all?
01-25-2026 11:01 PM
Many thanks 🙏
01-25-2026 11:00 PM
Hi thanks, I was completing account setup, got the new SIM card number in, attempted to transfer old number from Koodo, waited for message to confirm transfer, eventually the page showed that it had failed and I should seek support. Never got a text from public to complete the process
01-25-2026 10:57 PM
01-25-2026 10:56 PM
@Yamest No worries support can help
