Need help I’m using iPhone X but Public SIM card not detected.
Manav2812
So I have purchase pre-paid SIM card.have successfully Completed all the process but in the end when I have completed Payment after all inserting the sim into my Device but sim doesn’t recognise the sim..I have already done with phone switch-off.Restart the network settings and also Manually change the provider setting.
@Manav2812
I have an iPhone X and no issues. The iPhone X was introduced in 2017 so there is a possibility that it might be locked.
Go to Settings>General>Carrier Lock. If it is unlocked it should indicate No SIM Restrictions. If it is locked, it will indicate the name of the carrier then you need to contact them to have the phone unlocked.
@Manav2812   what is the error message? No SIM?  Sim not provisioned?  No Network?
since it is a new activation, it is very likely a sim card provisioning issue.  It is an easy fix for PM , but you will need to open ticket to engage them:
1. Please open ticket via Chatbot (requires access to My Account): click this  Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
Manav2812
Yes I can use in another iPhone but things comes in mine phone.and I’m not able to purchase new one
HALIMACS
@Manav2812
Try the SIM card in another, known to be working, device to determine whether a SIM/account or device issue.   While you're at it, try that other device SIM card in your iPhone to see if it works as expected.
Also, were you porting your number from another provider when coming here...
