Need detailed instruction or steps to check voice message from out of country
mikga
Please anyone can advise detailed instructions or steps to check voice messages from overseas - will be away for 3 weeks and need to access voice messages for some business related matters
Thanks!
9 REPLIES 9
mikga
Okay thanks!!
@mimmo wrote:
Before you leave I would do a test setup just to work out and issues in setting up you might have. Remember you have to setup the forwarding in Canada.
mimmo
mikga
Great idea! I have fongo #.. that's what I want to check my messages with when I'm away.
Thanks a lot!!!
@mimmo wrote:
I would get a fongo number(free) then forward you pm number before you leave to the fongo number. Then there is.no need to check voicemail. You will see missed calls and have visual voicemail. You can also all Canadian numbers when on wifi or if you have a local sim with data.
koimr1
I did this when I went to Europe this summer, Fongo was set to just send any voicemail as email which I received whenever I had data (wifi or via roaming sim). Worked perfectly!
mimmo
mikga
Great thank you both! And how can I change the password to retreve message from another phone?
Thanks!
Call your number from any phone with a keypad. When you hear your "away message" press * once and foillow the prompts. You will need to remember your 4 digit voicemail PIN. Try it before you leave.
mikga
Or anyone can tell me how (detailed steps) to check voice messages from another phone!!!
