Phone not working, data missing etc...
12-12-2018 02:05 PM - edited 01-05-2022 02:47 AM
Where is support?
Sent two messages to the moderator team over a day ago.
Joining Public
12-12-2018 02:10 PM
@anbertin, are you having problems only with data or are other features also not working. If it is only data that is not working, then it is very likely you need to update the APN settings on the phone. Check out this knowledge base which covers setting up the APN. BTW, moderator team response time is around 3 days. You will likely receive a response in the next day or so.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Activate/ta-p/251824
12-12-2018 02:09 PM
They will respond. Can the community assist you? What's going on?
We can't fix account issues, but we can advise on direct to proceed.
