Reply
Retraité / Retired
How do I check my Voicemail?
You can check your Voicemail in two ways:
• From your phone dial your phone number or press and hold 1, enter your    password and follow the prompts.
• From a land line or other mobile phone dial your phone number, press Star key (*), then enter your password and follow the prompts.
Re: How do I check my Voicemail?
You can set up your message system so that when you can yourself from yourself, you don't have to enter any password and go straight to your mailbox.
Call yourself, not can.
