Need US calling add on?
mya2002
My account is topped up but when people try to call me it says that need a US roaming add on for their account, and when I try to call it says that the call cannot be completed as dialed. We all live in Canada with Canadian numbers. This is for multiple people.
8 REPLIES 8
@hTideGnow- You mean to reboot this that this place seems to run on? 🙂
HI @dust2dust maybe it is PM system needs the reboot . LoL
@hTideGnow- I'm trying to rule out that their account is active. We had one of these not long ago where the customer came to realize that their account was suspended. The US message seems to be an error in messaging from this place. Quelle surprise.
@dust2dust wrote:
Can you otherwise do real sms texting (not just imessage to another iphone) and browse the internet on cell data (not wifi)?
HI @dust2dust
So, you think so how the system sees the phone/account really in US now?
dust2dust
HI @mya2002
this is one of the latest glitches.  If reboot or putting a 1 does not help, you really have to submit ticket with CS agent and have them to fix it on the system.
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@mya2002
Try calling them by adding “1” in front of the area code.
@mya2002 - if you are in Canada you should not be receiving this message, but others have been reporting this too.
So, try:
  • restarting your phone
  • toggle into airplane mode and back again.
  • preform a reset of the device's network settings
  • Can you try your SIM into another phone, then put it back in your phone, then try calling again
If issues persist, submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
