Need PUK
01-10-2024 08:05 PM
I just activated a new SIM card. It showed it was succeeded and got a new phone number. But after I installed the SIM card, it didn’t work and ask me a PUK code . Who can help me to get the code?
Other
01-10-2024 08:11 PM
@Cindyzh If it actually SIM like you need . Only support can help with that
send a private message To CS_Agents
01-10-2024 08:07 PM - edited 01-10-2024 08:08 PM
What is the message you're getting?
If you're getting:
"SIM network PIN blocked. Enter SIM network PUK." on a Samsung phone then call Samsung at 1-800-726-7864 and they will give you a code to unlock it. They'll want the IMEI of the phone in question.
If any of these:
- "SIM network unlock PIN"
- "SIM ME lock code NP"
- "SIM not Supported"
- "SIM locked"
- "Network Unlock Code"
- "SIM PUK code
- "Network Control Key"
- "Master Unlock Code"
- "Network PIN",
These mean the phone is locked to a previous provider. You'll need to contact them to unlock the phone.
If any of these:
- "PIN unlock key (PUK)"
- "Enter PUK Your SIM cannot be accessed"
- "Locked SIM"
then contact support:
