Need PUK code
NinuccioDP
Please help!
I get message saying tu enter 8 PUK code
(and No ! I do not have anymore the sim plastic "container".
TKS
@NinuccioDP
You can check your SIM/eSIM PUK on your phone by going to About settings on your phone and the ICCID then contact a CS_Agent for the PUK of the SIM/eSIM.
Having the packaging on the plastic surrounding the SIM card wouldn't help even if you did still have it.  Please diregard the misinformation that comes up in internet search engines about this.  The SIM card's PUK is not on the packaging.  I've actually never seen that for any carrier's SIM cards (although it is possible that some carrier might provide it there).
@NinuccioDP  If it’s just sim PUK you need support can help but if the phone is carrier locked you need the carrier the phone came from to unlock it for you
send  a  private message   To CS_Agent
hi @NinuccioDP
is it the sim card puk that you need?
if it is, support agent can help.  Please submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
