Need PUK code to use SIM for my son's phone; cannot log in to account without SIM
kev1n
Hi. My son's SIM has been locked and he needs a PUK code. Unfortunately, he cannot log into his account to ask for support because he cannot receive the EverSafe text with the access code, thus I am posting here on my account to get some help.
Can someone please help? The FAQ says a moderator needs to assist with PUK codes?
1 REPLY 1
@kev1n
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM  Card, SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
         open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
            **Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply to you there.
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK."
      call  Samsung 1-800-726-7864 for a master unlock code.
      The only info you will need to provide is the IMEI and where the phone was purchased
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
          You have to ask the carrier where you got the phone from for the carrier help unlocking it.
           (Sorry, for this particular issue, PM support would not be able to help)
